Old 06-09-2008, 05:22 AM   #10
ukchris
Why bother with the buckle at all? If you're going to compromise the integrity of the mechanism by tripping it with a match why not just cut the wire and put a two pole swithch and a copule of resistors in instead? All the buckle mechanism does is trip a switch to change the resistance in the circuit, the car detects this and enables or disables the airbag as appropriate.
I understand why people want to use the buckle as the "proper" solution as safety is involved but personally I'd trust a switch I'd installed over a buckle activated with a matchstick.
Chris.
http://www.lawlai.com/sig.jpg
ukchris is offline   Reply With Quote
