Old 05-19-2008, 03:46 PM   #2
vipola
hi Jaxonalden and Keith Newby, thanks for your fast reply and suggestions..
Originally Posted by Jaxonalden
Then try and unscrew the nuts with a socket because this will cause the nuts to force their way back off the shank.
Tried almost that holding the heads pin with a visegrip and pulling up while unscrew from below with the 8mm socket, Also tried to turn it from the top with the visegrip..
No results.. :/
I think what happened is that those blade from the screw went very deep into the metal when the guy pulled on the crest, so they can't unscrew anymore..
I see two solution.. try to drill the head from the top.. or try to drill the nuts from the bottom.. that's why I'm searching here for help and suggestions
vipola is offline   Reply With Quote
