Old 05-06-2008, 10:43 AM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
On the front suspension there isnt a eccentric bolt.. thats only on the rear However the front DOES have camber adjustment at the top of the strut mount where you had looked... you have to loosen the 3 nuts at the top of the strut mount when the car is jacked up off the ground and you can slide the strut mount left to right to adjust the camber.
Also i would take it to another alignment shop if your guy looked at the top of the strut and didnt see the nuts for adjusting camber.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
