Old 04-15-2017, 04:15 AM   #1
2004 UK Boxster brake issue
I have had the ABS/PSM Failure message on the dash come up. I checked my brake fluid and it was on minimum. Topped it up and it dropped again.
Took it to the workshop and my brakelines are corroded. Mechanic says it's a big job depending on how it goes with callipers. One piece line between servo and caliper they say
Anyone else had this done?
Lanark is offline   Reply With Quote
Old 04-15-2017, 07:41 AM   #2
2003 S, Arctic Silver, M6
paulofto's Avatar
You might want to check with Gear on his vehicle since he just did his brake lines and he is in the UK as well. Engine out to do brake lines seems odd.
Ger's 2003 Porsche Boxster S
Old 04-16-2017, 12:50 PM   #3
Looking at PelicanParts website and their parts diagram the engine and suspension do not have to come out the hard lines are in sections so it's a case of doing a bit at a time.
Old 04-16-2017, 01:50 PM   #4
edc
550 Anniversary
edc's Avatar
Depends which lines are corroded. You can either buy the length from OPC or get some made up to suit. £3k seems proper expensive. I've had a couple of hard lines done and it was nowhere near that price.
Old 04-17-2017, 12:08 AM   #5
Found it. Thanks for the link
Old 04-17-2017, 12:43 AM   #6
edc
550 Anniversary
edc's Avatar
Eporsch in Bisley.
Old 04-17-2017, 01:58 AM   #7
Originally Posted by edc View Post
Eporsch in Bisley.
Great that's not far.
It's the rear lines
Old 04-17-2017, 03:15 AM   #8
edc
550 Anniversary
edc's Avatar
Tell Dean or Roly Ed with the blue and silver Boxsters referred you.
Old 04-17-2017, 05:47 AM   #9
Will do.
Thanks for the info
Old 04-18-2017, 10:08 PM   #10
Update
The braking system has a connecter box about halfway down the car on the passenger side. It's leaking from there and is a common fault. No big deal to sort out.
