Old 03-30-2017, 02:04 PM   #1
2002 Porsche Boxster S Instrument Cluster
Hello, bear with me while I ask the question, I read some of the post related to 986 cluster upgrade but I need to confirm before spending the money.
Background:
I have a 2002 Porsche Boxster Base model, and I am looking to upgrade the instrument (MPH) cluster from a 2002 Porsche Boxster S (White Face).
Question:
1. Is it compatible for an easy swap?
2. Is there anything I needed to do to make sure it work properly? Beside the ODO correction.
Thank you!
rowescompany is offline   Reply With Quote
Old 03-30-2017, 05:22 PM   #2
KevinH1990's Avatar
It should be an easy swap. The top speed on the S cluster may be a bit higher than on the base.
Here's some information about clusters if you are really interested in how they work:
Programming a 996 Cluster to Work in a 986 - Rennlist Discussion Forums
996 Instrument upgrade - Rennlist Discussion Forums
Old 03-30-2017, 06:07 PM   #3
Thanks Kevin.... I will look into it.
