Old 12-10-2016, 10:37 AM   #1
The Radium King's Avatar
35 ET on rear?
hi - anyone running a 35 ET on the rear w/ 10" wheels (say 275 rubber)? here's a pic of my car w/ 40 ET 10" 275 and not sure i can fit that extra 5 mm but not a lot of experience w/ this stuff and have a line on a set of wheels ...
Old 12-15-2016, 10:29 AM   #2
I'm running 19x10 et 35 on my Boxster tires are 255 though but there still is about a 1/2 inch from wheel to fender.
jdf1029 is offline   Reply With Quote
Old 12-15-2016, 01:59 PM   #3
thanks. with a 275 we are looking at an additional 20 mm or 1", so 1/2" each side - it would be cutting it darn close in my case hey?
Old 12-16-2016, 05:03 AM   #4
Yea I would say without any type of camber adjustments it would be very very close to hitting the fender with a 275 tire on.
Old 12-16-2016, 05:29 PM   #5
LAP1DOUG's Avatar
For my rear, I normally use a 10" OZ with an et 40 offset, with a 3 mm spacer, which brings the total offset down to 37 mm.
I am using this with a 285 30-18 RE71R tire, which has a maximum section width of about 11.4" on this wheel.
With my ride height and -2.5 degrees camber, this set up does not scrub the fenders, but looks like it is about the widest set-up possible without rolling fenders.
Yours may work, but it will be close.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
Old 12-27-2016, 11:47 PM   #6
I run 10 et35 with a 265 and 3degrees camber and 5mm spacers. Clears fender just. It is quite low. Close to the handbrake cables too.
jimk04 is offline   Reply With Quote
