Old 09-03-2010, 07:41 AM   #1
What could leak from Left Rear wheel? (it's oil)
I noticed a leak from left rear wheel in the last 2 days.
It's right in front of left rear wheel.. and it doesn't smell like coolant.
It doesn't look like oil it's more like water that washed an oily engine..
I did a search and it seems that coolant leaks are usually on the right or middle, oil leaks also should be in the middle.
Any iddeas on what could leak from left rear wheel? what fluids are going through there?
Sasha
sasha055 is offline   Reply With Quote
Old 09-03-2010, 07:56 AM   #2
manolo's Avatar
Hey Sasha,
Most likely its the water drain from the convertible top area. It drains out right in front of the rear wheels on both sides.
2003 Cayenne Turbo
manolo is offline   Reply With Quote
Old 09-03-2010, 08:01 AM   #3
That would be my first guess.. but it was sunny last couple of days in Seattle..
Can it be condensation? or water that didn't drain before?
Thanks Manolo.. hearing that it could be nothing wrong is always good!
Sasha
Old 09-03-2010, 05:22 PM   #4
It's oil that's leaking from there. Apparently Castrol Syntec doesn't smell.
It seems that it's dripping from inside on the support metal plate in fron of rear left wheel.
I'll lift the car this weekend to see where it's coming from.. any idees what should I look for?
Sasha
Old 09-04-2010, 09:54 AM   #5
jcb986's Avatar
Check for a spark plug tube leaking.
Old Hippie Young Heart
Old 09-04-2010, 02:00 PM   #6
manolo's Avatar
Maybe check valve cover also. Some boxster owners have experienced this.
2003 Cayenne Turbo
Old 09-04-2010, 09:39 PM   #7
Rennzenn
j.fro's Avatar
Power steering is on the left side, but I'm with the others on checking the spark plug tubes/ valve covers first.
Old 09-05-2010, 08:53 AM   #8
Thanks for all the responses.
How do I check valve covers? where are they located and how they look?
Is there a DIY with pictures somewhere?
Sasha
Old 09-07-2010, 10:59 AM   #9
Over the weekend I lifted up the car and took a closer look at where the leak could be coming from.
I still didn't get the source of leak.
It's a very small leak, a couple of drops every time I park.
It's dripping down from the protective undercover (the one that covers front engine mount, fuel filter.. etc).
Spark plugs were OK.
It seems that oil is getting there by running down on one of the tubes rather then dripping directly down.
I cleaned-up up everything so next time I'll get a better look.
I did notice one strange thing though. When I'm parking in reverse I get a cloud of white smoke. I suspected AOS but the smoke is not coming from exhaust, it seems that oil is dripping on something HOT in there and evaporates. Smoke is coming from rear left wheel.
Can AOS brake in a way that is letting oil out on the engine/exhaust? I didn't look at the top of the engine so I'm not sure if there's oil there. BTW AOS passed OIL cap tests.
Any advices what this could be?
Sasha
Old 09-07-2010, 01:58 PM   #10
I had the same problem
a month or so after I got my '00 S a couple of years ago. Same leak in exactly the same place. It turned out to be the cam tower seals. I had bought mine from a p-dealer so they put a short term full bumper to bumper warranty on it. They replaced both sides because they found it was seeping on the other side too. I'm not sure what it would've cost if I had to pay for it. There is a write-up somewhere out there on tightening the cam cover bolts to slow down or stop a leak. Maybe someone can chime in?
sean
SeanZ4 is offline   Reply With Quote
