Old 07-07-2010, 09:47 PM   #1
clutch slave
has anyone managed to change the Boxter clutch slave cylinder?
any tips??
rmt@telus.net is offline   Reply With Quote
Old 07-07-2010, 10:33 PM   #2
No personal experience...haven't had to do it.
Try here: http://www.pelicanparts.com/techarticles/Boxster_Tech/45-TRANS-Clutch_Hydraulics/45-TRANS-Clutch_Hydraulics.htm
Old 07-08-2010, 10:50 PM   #3
jwright
Rebuilding of the clutch slave is needed when the clutch petal is not working. It is also necessary to see weather the clutch container is full or not and it is directly attached to the transmission casing. Clutch slave cylinders are the best with their performance and models.
Old 08-01-2010, 11:06 PM   #4
You can easily buy a clutch slave cylinder line and find a good price too. may need a new clutch slave cylinder, if the car begins to lose hydraulic fluids. There are a number of clutch slave cylinder out there and they are all food for the various car models.
Debt Management
jonnyj99 is offline   Reply With Quote
