Old 03-11-2010, 04:26 AM   #1
Front drain problem
Hi folks,
One of my front drains has been pushed through, the bung is no longer attached. Any ideas how I can retrieve this and relocate the drain please?
Paul Whyte is offline   Reply With Quote
Old 03-11-2010, 02:34 PM   #2
Steve Tinker's Avatar
You have to remove the appropriate wheel which allows you to see the (~20mm dia) drainage hole. If you are lucky, you will see the L shaped rubber piece lying in the appature. I had to find mine with the aid of a torch and a bent wire. The rubber drain will push strait back into position.
2001 MV Agusta F4.
Old 03-15-2010, 05:33 AM   #3
Thanks for the info, I shall give it a go.
