Old 06-04-2008, 02:35 PM   #1
Car cannot start. Dash light flashes wildly. Please help
Hello,
I hadn't been reading the tech forums for over half a year now and I have totally forgotten all the famous problems the Boxster possesses.
I need a quick reminder of what my problem is. I have been searching but I can't seem to find the description of the problem I am facing now.
My problem is my Boxster suddenly won't start today. I stick the key in and the dash lights will flash wildly and my windows went down an inch and back up repeatedly as well as I can hear the starter in the engine ticking. It doesn't seem to be a battery problem because all the lights are on brightly.
Is this the famous ignition switch problem? My key goes in and out of the ignition fine.
I remember reading this exact problem people had before, but I can't find it now.
Could someone please remind me what this issue is? Is it battery related or ignition switch?
thanks very much
Ken
03' Boxster
http://members.shaw.ca/kendrick922/boxsterbb.jpg
kdub is offline   Reply With Quote
Old 06-04-2008, 02:52 PM   #2
bmussatti
My bet would be a bad ignition switch.
Old 06-04-2008, 03:03 PM   #3
could be switch but also check under driver's seat for any moisture/water....
Old 06-04-2008, 03:40 PM   #4
SOunds like the battery has failed.
wvicary is offline   Reply With Quote
Old 06-04-2008, 03:49 PM   #5
Yah? I kinda think that maybe the problem because I hadn't driven the car for a couple weeks. But my car is parked underground and there are no power outlet near by for me to trickle charge it.
03' Boxster
Old 06-04-2008, 06:54 PM   #6
You have a problem with the battery.
Old 06-04-2008, 09:12 PM   #7
Lil bastard's Avatar
Yep... battery, ignition switch or alternator (which caused the battery to go bad).
Eliminate the battery and alternator by checking them with a DMM. If the battery reads 12.6 volts from terminal to terminal, cables off, and cables on, car running same test voltage should read 13.6 - 14.5 volts (alternator voltage), any other values and this is your problem.
If these check out, then it's the switch.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 06-04-2008, 10:32 PM   #8
I changed the ignition switch and it still didn't start. So it has to be the battery.
I took the battery out the car and am charging it now with a battery charger.
03' Boxster
