Old 04-28-2008, 08:53 AM   #1
Send a message via Yahoo to bermuditis
DYI rear plastic window.
Has anyone purchased the DYI plastic replacement window kit on line and did it work? I'm thinking of buying the kit for a hundred and installing what is supposed to be better quality material. It also comes with tinted plastic for $18 more. Let me know what you think.
bermuditis is offline   Reply With Quote
Old 04-28-2008, 09:09 AM   #2
I have. It is a lot of work, much more than I had anticipated.
If your on Renntech I sort-of took over another thread about a top, there are a couple pics there as well as some discussion of the process:
http://www.renntech.org/forums/index.php?showtopic=17836&st=20&p=94287&#entry94287
The material is not as clear as the original window material, but seems more supple and compliant. If you are not a hardcore DIYer and do not have someone to help you with the stitching I would recommend you find a shop willing to stitch in a new window with the canvas still on the frame. The entire convertible top (canvas & frame) is surprisingly easy to remove. Most shops want to remove the canvas from the frame, that is where it gets expensive.
Also see this thread where we touched on the subject:
Replacing plastic back window '01 Boxster's Top
kabel
Old 04-28-2008, 04:11 PM   #3
GOOD LUCK
I attempted this on my old Z3 and just about lost my sanity and still did not finish it. I had to take it to a local upholstry shop for them to finish it. IT SUCKED BAD!!!!
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
