Old 09-07-2007, 02:23 AM   #1
Unhappy Please help me diagnose a clutch/gearbox problem?
2nd gear in my 2002 Boxster S has recently statred to become problematic. Sometimes when I change gear it imediately slips out as soon as I lift the clutch. I find if I want to put it in second I have to release the clutch slowly whilst accelerating slightly. If I try to change in a normal manner it grinds. A couple of times it has actually slipped out of second whilst I have been driving also. It seems more of a problem when changing down than up. I have no issues with any other gear whatsoever, just second gear.
Does anybody know from the symptoms what is the most likely cause of such a problem? I suspect a new clutch but am dreading the possibility there could be a serious problem with my gearbox. I can barely afford the car as it is.
jameswithers is offline   Reply With Quote
Old 09-07-2007, 03:44 AM   #2
Sounds like the synchro has gone on that gear rather than a clutch problem. Either way it is worth getting it checked out.
If you have a warranty go to your local OPC, if not try one of the local specialists. JZ Mactech are worth talking to, my friend "down south" gets great service from them. I have no experience of them.
http://www.jzmachtech.com/
noone986s is offline   Reply With Quote
Old 09-07-2007, 04:38 AM   #3
Unhappy
Thanks for the advice. I will get in touch with the people you mention. It sounds expensive, I dont suppose you have any idea how much it is likely to cost me to get a new synchro mesh for his gear? I assume they would need to take out the engine and gearbox etc etc, souds like its going to cost me a packet ....
Old 09-07-2007, 04:49 AM   #4
I have no idea on price sorry. Its about 6 hours labour to remove and replace the box so if it is this problem and not something trivial like shifter alignment then you could be in for a bit of wallet pain, sorry.
Get it checked out first, no point worring until you know exactly what is wrong. Good luck
Old 09-07-2007, 04:55 AM   #5
Ok, thanks again for taking the time to reply. Its certainly time for a specialist to check it out. Fingers crossed its not a gearbox rebuild, though unfortunately I am starting to fear the worst now ...
