12-11-2005, 04:00 PM
Front emblem flew off.
So I'm showing a cousin my Boxster S and at about 90MPH, I saw what I thought was a leaf blowing up over the hood. When we parked, I saw that the front Porsche emblem had blown off. Anybody know where to get a replacement and how much money? Thanks.
2002 Triple-Black Boxster S
12-11-2005, 04:08 PM
Call Suncoast's parts department tomorrow morning when they re-open- 877-293-1700. You may want to order a silver one this time.
12-11-2005, 04:20 PM
The gold one's part number is 986 559 211 01. Should be less than $50.
12-11-2005, 04:35 PM
Obvoiusley, there are a bunch on E-bay too! Mke sure you get a new rubber seal too, that probably flew away with the emblem.
12-11-2005, 08:01 PM
the 986online.com site sells em for 50 something. I had to replace mine too.
Never use a big word where a dimunitive one will suffice.
97 Guards Red
82k miles
12-12-2005, 05:08 AM
Senior Member
Yes...support our forum sponsors
12-12-2005, 08:53 AM
Thanks, I ordered today through 986online.com. I wish they had photos of the products, though.
12-12-2005, 10:48 AM
Good lord...this is the first I've ever heard of a hood emblem just blowing off on any car, let alone a Porshe. How does this happen on a 50k automobile?
That's sad....just freakin sad. Not to mention that emblem is weighty enough to make a nice projectile at 90mph, glad it didn't hit anyone.
06 987S- Sold
05 987 5-speed - Sold
06 MB SLK350- Lease escapee
12-12-2005, 10:53 AM
Very odd! One thing about these emblems is that they are bolted to the hood. There's no reason for it to fly off. Did you go to the dealership and tell them what happened? I wouldn't doubt that they'd replace it under warranty, as there's no reason for it to come off.
If you do put it back on yourself, might I suggest some lock-tite?
12-12-2005, 12:29 PM
Thanks, Eric. I'm wondering if somebody had tried to pry it off as a souvenir and loosened it.
One never knows, do one?
12-12-2005, 01:52 PM
My thoughts exactly.....They are very very easy to just pull off... Im on my third one (First two were takin while still in high school...damn kids)
12-12-2005, 04:29 PM
Hrmmmm really? Maybe it's different on the 987 then because I can't see any way for anyone to just pry it off!
12-12-2005, 05:34 PM
They all go on the same way i believe...Two pins drop into the inside of the trunk with fasteners on the inside.
12-13-2005, 06:34 AM
The OEM Emblem is really quite cheaply made. The Base is just cast with two Threaded Pins. These threads are not cut into the Pins, they are cast in and not very deeply. They attach using an 8mm Nuts stamped out of sheetmetal and none too strong. It's quite easy to over-torque these Nuts, in which case, they bend and do a poor job of grabbing the Cast-Threaded Pins. I can quite easily imagine wind getting under one and ripping the emblem off.
That said, a Vandal can easily pry off the emblem without damaging the Hood excessively and this may, in fact, be the whole purpose to the very rickety system.
Using Locktite as suggested would most likely do no good. So far as the Rubber Gasket, this is designed to prevent water from running behind the Emblem and becoming trapped causing corrosion to the hood. But, there is a large circular cut-out in this Gasket to accomodate the attachment Pins. As such, it actually allows water to pool underneath it. Be sure to remove the Emblem (using an 8mm Nut Driver) each time you Detail and Wax the Car to clean and protect the area of the Hood underneath. Hope this helps...
12-13-2005, 02:59 PM
Originally Posted by dbth
MNBoxster :Jim , I have missed your input on this forum , where have you been?
Yes, I've been absent the past few weeks. My comp died and then we left for a 3-week vacation to Florida, Georgia, and South Carolina.
Spent a week at SawGrass in Jacksonville Beach, where Mrs. MNBoxster spent a couple hours each day at the PGA Offices planning next year's Tour and World Golf Association events (she runs 'em).
Then we drove up the coast and spent 5 days in Savannah at the Olde Harbour Inn on Factor's Walk, then further up to Charleston where we spent 8 days at the Planter's Inn at the Market. Generally, a lot of Great Food, Wonderful Wine and miscellany Decadence.
Had an exceptional time, still... it's good to be home...
12-16-2005, 06:18 PM
If you are thinking that you might want a silver hood crest, you should get one soon.
According to both the Newport Beach Porsche dealer and Wheel Enhancement in LA, Porsche has cracked down on anyone refinishing and selling the OEM crest in silver. The Porsche dealer had a silver crest in stock but had to pull it from the parts department. Apparently Porsche thinks the crest should be gold plated only and will not authorize silver substitutes.
