Old 01-11-2007, 01:20 PM   #1
Problem with headlights
Hi guys!
So i changed the right headlight bulb on my boxster after it went, but the bulb that i put in wasnt as bright as the one in the left headlight.
I then put a new bulb in the left headlight, thinking it was just a different type of bulb, but no! So 2 new bulbs and 1 side isnt as 'blue' like the other.
I've changed the fuses also. Any suggestions would be MORE than welcome. THANKS!!!
drew900uk is offline   Reply With Quote
Old 01-11-2007, 03:49 PM   #2
Blue? Are they the same brand? If so, my guess is you bought a bad bunch. Try replaceing both lights at the same time with non-blue bulbs.
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
2000 Porsche Boxster | SOLD | http://www.986forum.com/forums/showthread.php?t=9114
http://www.kryzak.com/storage/986sig12.jpg
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
Old 01-12-2007, 11:50 AM   #3
Send a message via AIM to BOX5TR
I had this same problem! I have litronic headlights on my 2000 boxster, and when in the shop they replaced one headlight assembly. The new headlight was brighter, and whiter - while the other older headlight was not so bright and had more of a blue tint to it - which is what I liked.
I did the same thing you did, thinking it was the bulbs... but (and perhaps someone can explain this better than I can) it has something to do with the headlights age. I've had my headlights slightly unmatching for about 6 months now -- but I can already tell that they are almost normal and matching. You just have to stick it out and let the other headlight "die down" a little and they will start matching in color. They get more of a blue tint and slightly less dimm as they age. The only other option is to buy 2 new headlight assemblies - which we know is $$$$.
Thats what I found in my situation.. and thats what I heard from my local Porsche shop... good luck with that. I'd say just hold off and let mother nature match them up. I know its annoying as hell... but...
BOX5TR is offline   Reply With Quote
HTML code is Off
