Old 02-02-2024, 05:27 PM   #1
Ron986's Avatar
Boxster 3rd Brake Light Emblem
I've been toying with the idea of adding 'PORSCHE' to the rear of the Boxster. I discovered that the 3rd brake light has 7 lighted segments, which perfectly matches the number of letters in the word Porsche. The problem is the light does not allow much vertical space for letters. And the 'small' stick-on letters I could find (Amazon & eBay) were to tall at either 3/4" or 1". I needed 1/2" letters to make this idea work. After more research, I found that the Porsche emblem off a 356c has the correct letters. I sourced a used emblem from eBay, refinished it and stuck it on with 3M double sided tape. Here are the results...
Ron986 is offline   Reply With Quote
Old 02-03-2024, 08:37 AM   #2
BruceH's Avatar
Nice
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 02-05-2024, 12:08 PM   #3
WALDMEISTER
BRAN's Avatar
There you go.
I probably would dremel those connecting bridges.
Your idea might cause trouble with our TÜV, probably not so much with the Polizei.
Old 02-05-2024, 01:12 PM   #4
There you go.
You Polizei aren't the only ones; in several states, anything "obstructing" the third brake light is illegal and favorite ticket bait.......................
Old 02-08-2024, 04:04 AM   #5
Thumbs up
ducker18 is offline   Reply With Quote
Old 02-08-2024, 07:17 AM   #6
Great idea, but the only emblems I can find are $100+ dollars, not exactly something I want to do on a whim.
redpepperracing is offline   Reply With Quote
HTML code is Off
