05-10-2017, 03:14 PM
#401
After that, I couldn’t stop staring at the gap beneath the radio
So I tried to make a temporary fascia to fill it.
Found an old drawer that I was throwing out and it was the same thickness
Sprayed it matte black
Voila!
It’ll do for now!
Porsche Boxster S Type 986
05-10-2017, 03:24 PM
#402
After this, I decided to take the plunge and spray the exhaust tips and diffuser area matte black, so that of a 987 black edition. The diffuser fins on mine were the part I hated most. Stainless steel exhaust tips, grey exhaust surround, with black paint?
So I was going to spray the diffuser and tips matte black, so the rear looks more purposeful (like a diffuser), separates itself from the bumper, and to give a clean look for the exhausts.
Decided to do the tips separate from the fins.
Underneath of them weren’t too clever
And after:
Masked them up to do the fins and exhaust surround
And here, ladies and gentlemen, is the final result.
So much better.
What do you guys think?
05-10-2017, 03:35 PM
#403
The strip under the radio and the exhaust tips look great, very nice! Of course the rest of your work is also first rate
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
05-10-2017, 03:43 PM
#404
Appreciate the kind words  thank you
05-11-2017, 04:50 AM
#405
Is the diffuser a factory option or was it added on later? I like the look of it.
05-11-2017, 06:10 AM
#406
It was added on the facelift model as standard, but you can buy them to fit pre-facelift's.
05-11-2017, 07:27 AM
#407
Ger's 2003 Porsche Boxster S
Hey, it worked! I've been waiting to see how this one would come off and, whilst it's hard to see in the pictures, I think it's modernised the rear without looking at all out of place. How does it look in person?
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
05-11-2017, 07:32 AM
#408
100x better.
I'm tempted to film it, just to see it from all angles at the same time as the photos really don't do its justice. It looks so clean and new!
Which has got me thinking...
Newer Porsches (Boxsters, GT3RS, Turbo, etc) have matt black side vents. I'm tempted to pull them, spray them and fit them back in. I imagine they'd look really, really nice contrasting against the glossy paintwork.
05-11-2017, 07:45 AM
#409
It's barely relevant given that it's a yellow car, but this guy did it.
And check out that interior!
Pics of my speed yellow Boxster S will All leather interior
05-13-2017, 04:25 AM
#410
Seen that, it's beautiful!
You know, about a year ago I did a 2-stage paint correction on the car, and while people think I'm nuts using three buckets (one for wheels), two grit guards, two detailing brushes, a sheepskin wash mitt, wheel woolies, drying towels and a lot of patience just to 'quickly' wash the car, this is the result after a year's worth of daily driving a 14 year old car. Not a single swirl mark - the paint still looks new.
Also the hydrophobic coating on the roof still working a charm
05-13-2017, 04:54 AM
#411
WALDMEISTER
So much better.
Looks really nice! No worries, that it might bubble?
05-13-2017, 11:02 AM
#412
05-13-2017, 03:31 PM
#413
Simply outstanding! Unless you have a black car, no one truly knows how utterly hard it is to make it presentable. Every other color hides so many blemishes but black will not only show, but highlight the smallest defect. To look this good is beyond remarkable. Well done......
05-14-2017, 01:34 PM
#414
Appreciate the kind words, thank you
I was a little skeptical about buying the car, but have learnt a lot about car detailing and what not since owning it!
05-15-2017, 07:33 AM
#415
Beautiful car, excellent condition!
05-21-2017, 01:04 AM
#416
Many thanks!
06-03-2017, 08:59 AM
#417
So I had an eventful bank holiday... almost crashed the car!
Driving at 30mph (luckily) and the rear left suspension collapsed. The track arm had sheered its bolt that goes into the hub, allowing the arm to break free completely, resulting in my back wheel turning in completely and kicking the back end of the car out. Was absolutely fine, I didn't hit anything and pulled over safely and inspected the damage.
Luckily it was just the arm that had been damaged and no other parts, but thankfully I was only doing 30mph. If I had been doing 70mph+ (like I had been moments earlier), it would have been a different story. But no biggie, could be worse! I intended to replace the arm and get an alignment done, and have it back on the road.
Called for the recovery, and in all fairness they were exceptional and took good care.
The next morning, I took the damaged part off. Now there should be a bolt on the end of this where the nut screws onto, but that's broken off. What's more worrying is that there's only clean metal through a small part in the centre.
Was this all that was holding it on? Perhaps a design flaw from the factory, or maybe it had been cracked a while ago? Either way, it was only a matter of time before this failed.
Anyway.****I popped over to EuroCarParts and picked up a new arm for £60 (bit of a deal made). Went back and fitted the arm, all was well.
Took it for a quick test drive and the car was handling horrendously, with the back end twitching over every bump. Completely expected this as the eccentric bolt that I took off to get the arm off completely controls the toe and can alter the camber of the wheel, so the wheel was miles out.
Took it straight to a very reputable garage to have it put on a Hunter system to get all four wheels aligned back to factory spec after the accident.
Incredible bit of kit, using lasers and pattern boards to identify the wheels caster, camber and toe.
No bolts were seized, the whole process was a doddle.
This was the alignment before (expected to be horrendous due to the new arm fitted)
This was after:
Now the reason why the rear left camber is slightly out is because of my own wrong doing. When I changed the part, I had to take off the eccentric bolt and put it back - the bolt with the egg-shaped washer that, when turned, pushes and pulls the arm to adjust the toe. Well this has two washers, and I think I've put them on so they don't match with each other, which isn't a problem, but****results in the bolt being completely useless to adjust the toe properly unless I take it all off and re-fitted it correctly. The guy managed to get it as close as possible and adjusted the camber so that the toe was in but camber slightly off, as it's a lot better to have the camber off than the toe off.****
Even so, he assured me that the amount that it's out will make absolutely no real world difference as it's only 0.07 degrees out of the limit. I'll probably re-fit that bolt in the future but it'll just be for the sake of it as it wouldn't really make any difference.
Car was finished! £60 for the part that I fixed myself, and £60 for all of the alignment. Car was back on the road the day after the accident. Cheap and cheerful!
Took it for a drive. WHAT A DIFFERENCE! The alignment must have been out previously, as I'm blown away by how confident the car feels in turns, and how it feels like it's on rails in a straight line. Nothing upsets the steering, it doesn't budge going over any bumps in the road. Just feels like a new car. Any car I buy in the future, I'll be taking it there to get a full alignment done. I wish I did this before.
Also, on my drive, this happened!
100,000 miles!
Very pleased with the car at 100,000 miles. Aiming for the next 100,000 now!
06-03-2017, 11:12 AM
#418
No, not a design flaw. That is the result of a poorly torque joint. A quality torque wrench and official specs are paramount for vital links like these. Sorry if this comes in harsh but it is what it is mate.
Glad you and the car are both okay. Congrats on your 100k!
06-05-2017, 01:25 AM
#419
Not harsh at all, I've never touched the bolt so must have been a previous owner/mechanic  I've got two torque wrenches that I use when working on the car.
And thank you!
06-05-2017, 01:29 AM
#420
Speaking of not having touched that bolt - how has the driveshaft boot worked out for you Ger?
I recall that you used one which didn't required the shaft to be removed, which I'd have avoided but I'm curious to know how that's panned out for you so far as it's quite a time saver...
HTML code is Off
