-   -   Can someone post the 15k Maintence list? (http://986forum.com/forums/show-tell-gallery/4331-can-someone-post-15k-maintence-list.html)
phrankandbeanz 11-24-2005 10:53 PM
I tried to search for it using the search feature of the forum however, I came up empty handed. What do I need to do for the 15k service?
blinkwatt 11-25-2005 03:56 AM
It is listed in the owners manual. If you do not have that them here is a list.
http://www.986faq.com/7-0/schedule.asp#001-001
bmussatti 11-25-2005 10:21 AM
phrank, it is on the list that blink sent you, but near the bottom, so don't miss the part about changing the brake fluid every two years...very important.
phrankandbeanz 11-25-2005 03:57 PM
thanks guys, i found all the procedures also on renntech. Time to give suncoast a call!
phrankandbeanz 11-28-2005 08:03 PM
how many bottles of oil do I need? Do I only need to order a pollen filter and an oil filter for the 15k job?
Adam 11-28-2005 09:14 PM
^ 9 quarts should be fine as long as you drain them out well. The answer to your second question is yes. As mentioned earlier if it's been 2yrs or more since the brakes have been bled...you should do them too.
