Old 08-14-2010, 10:27 AM   #1
Picture + question
Picked up my 06 boxster with 26k miles at the beginning of the month. Have noted that it had a service at 14k and oil change/new front pads/fluid change before I got it. Both these were done by an independent garage. It has never been in a porsche main dealer.
Concerned I asked the porsche dealer for advice and he recommended a porsche 4year service at £800. Only one main dealer in Northern Ireland and I dont know a good independent. The dealer said the plugs would need changed etc and as i am going to use it everyday day i want it right.
What would you suggest? I have always had my cars serviced by a main dealer and would like peace of mind!
First porsche after 17 different cars as now time for some fun! However not as well versed on their needs.
Jim
flops is offline   Reply With Quote
Old 08-14-2010, 10:35 AM   #2
tonycarreon's Avatar
I would certainly do an oil change which is an easy DIY. Most of the Porsche service is inspection work - checking belts, fluids, looking for leaks, etc.
My plugs were not changed until 60,000-something miles. If you want piece of mind find a good Indy and take them a list of things to check out. I probably wouldn't go to a Porsche dealer because of the higher price.
Old 08-14-2010, 11:24 AM   #3
When I bought my car used with 35K miles I just went ahead and did the 60,000 mile service - plugs, air filter, fuel filter, cabin filter, oil change, transmission oil change, flushed brakes, etc. I did this like you are suggesting for peace of mind. I wasn't sure what service had been done before, but at this point I had a foundation that I was sure of that I could build from.
I don't believe there is anything magical about the Porsche dealer technicians, unless you have an electronics problem where a PST2 computer for diagnosis is needed. I did all of my own work and trust that a good independent (adept with Porsches) could change the oil and filters just as well (but cheaper) as a Porsche dealer.
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
HTML code is Off
