Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Off Topic > Regional Forum
Old 02-10-2011, 04:44 PM   #1
Tiptronic transmission replacement parts????
I have a 99 porsche boxster an the front bushings went bad causing it to leak where can I find a bushing replacement or a overhaul kit because the trans shifts an drove perfect just started leaking an don't wanna spend 2000 dollars or more because of a bushing....please help!!!
Dariusw18 is offline   Reply With Quote
Old 02-11-2011, 04:23 AM   #2
Are you positive it's the transmission and not the rear main seal on the engine? In other words are you leaking oil or transmission fluid? I think you can buy a dye you can add to the oil to verify one way or the other.
Dale_K is offline   Reply With Quote
Old 02-11-2011, 04:37 AM   #3
jcb986's Avatar
The final drive is between the trans and the engine and if the TIP is over filled you will build up to much pressure and force TIP fluid into the final drive. If the final drive gets to much fluid there is a air hole above the final drive axle cover. If the oil is leaking where the two connect, it's most likely the RMS. TIP fluid has a very distinct smell over engine oil. I have a leak on my drive side of the final drive unit and will need to replace the seal...maybe you have the same since this is a common area for a leak.
Go here and view or download parts catalog and you can see the TIP diagram:
http://www.********************************************.com/porsche-parts/boxster.php
Old Hippie Young Heart
Old 03-30-2011, 04:52 PM   #4
If you need a tiptronic I just pulled a perfectly working one out of a customers car with 60k on it.
He did a 5 speed conversion.
I love our online diagrams =)
Porsche Tech at ********************************************.com
986
914
love'em!
AutoAtlanta is offline   Reply With Quote
HTML code is Off
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
Copyright 2024 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
