Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Porsche Cayman Discussions
Old 10-20-2025, 08:53 AM   #1
kdh
987 Cayman - too much engine/transmission noise in cabin
I'd like to reduce the amount of engine/mechanical/gearbox/induction noise in the cabin of my 2.7 987 Cayman so I can hear the exhaust a bit clearer.
I'm not sure where it's coming from - is it from behind the seats or above the engine?
Would soundproofing help or would that deaden the exhaust even more?
Thanks.
kdh is offline   Reply With Quote
Old 11-26-2025, 10:19 PM   #2
That's a common 987 quirk! The noise primarily comes through the rear firewall behind the seats - strategic soundproofing there should reduce mechanical drone while preserving your exhaust note.
______________________
Driving the future with efficient bldc motor solutions.
samlevy0515 is offline   Reply With Quote
Old 11-29-2025, 03:12 AM   #3
WALDMEISTER
BRAN's Avatar
You might want to check, if your 987 was de-snorkled.
That will cause massive induction sounds (coming from driver side, above engine).
I like it though
HTML code is Off
