Old 03-05-2007, 01:29 PM   #1
rdancd816's Avatar
Drain locations on 986
Now that Spring and rainshowers are on the way I wanted to know where the drain locations are on the Boxster. Seems a good time of year to clean them out, just need to know where they are!
"97 Boxster" Guards Red, Coppell, TX 36,500 miles
2010 Mazda CX-7 AWD, Turbo, Grand Touring
rdancd816 is offline   Reply With Quote
Old 03-05-2007, 01:41 PM   #2
Theres one on the left and right side... Right under the convertible top, beside the large main bracket that the convertible top pivots when opening and closing... You also might wanna unscrew your mud flaps infront of your rear tires, the drain im talking about leads into the flaps, so you might have leafs and other junk stuck in there.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 03-05-2007, 01:43 PM   #3
rdancd816's Avatar
Good info...Thanks!
Old 03-05-2007, 02:20 PM   #4
Yeah your going to need an air compressor to blow any air out from that hole, the only thing you can do is remove any surface blockage.
Carlos J Cazares
Old 03-05-2007, 04:55 PM   #5
You have mail and
4 drains
1 from the HVAC
1 from the gas filler tray
1 from the water tray
1 from the leakage channel
I think these last two are actually duplicated on both sides under the top cover.
