Straight answer for tire size
I have the 8 inch front and 10 inch rear rims.
What is the maximum size I can run on the boxster with these rims...with and with out the 15mm spacer. Currently I have 225s on the front and 265's on the rear. Chris |
Id go a 235 and a 285.
spacers
is that with or without the spacers?
By the way
By the way Boggtown is that a GT3 front on your car? I have the GT3 as well...so my question is where did you get the grill to fit the nose....
Chris |
Diameter shouldnt matter. I put an aluminum mesh in after I cut it to shape and secured it with bondo glass. Id say without spacers because its generally getting the rim to fit is where you need spacers, but if it does rub a little on the inside strut, spacers would fix that.
Diameter
I have the 18x10" on the rear. The Sport Classic 2 wheels.
If I remember correctly the Sport Classic 2 doesn't come in a 10" width. I could be wrong though. You might want to double check. I think its a 18X9
Is that a 964 I see in that garage?? Or am I delusional :P |
Good eyes
The Sport classics are 10's on the rear.
Yes that is my 1974 911 in the garage, it will now become a full time track car for me. It has the duck, and will go in to the shop on Friday for some engine mods. I have a DE in Talladega in April so I need it ready... |
My favorite thing is a gutted interior 911. Are you gonna do custom door panels to cut more weight?
Dammit
I just pulled my rears off and they are not 10's they are 9J'sx18....
I put 10's with 295/30's on and it would only fit if I put a 20mm spacer on it. But it stuck out to far...... So,I guess we know that combo will not work.... |
spacers
the 20mm spacers are all we had in the garage at the time, everything else was larger.
The turbo twist wheels came from a 993 turbo...I think. But I think I just need the right offset for the wheels... Do you happen to know what that might be? Infact...I might just use your car as a model for mine. I have the GT3 nose, the side skirts are coming....And the 285 wheels would be great for the track. What is your rear wheel set up? and do you have any rub? As far as the 911 goes, I just thought about gutting it out strictly for the track and with the new PCA rule, put some 5 point harness and seat combo in it. I need to lighten the load! |
Ive got a 10.5 inch wheel with a 275 tire on. My rear offset is 52 and I use a 7mm spacer.
| All times are GMT -8. The time now is 11:55 PM. |
