Old 02-21-2007, 04:57 PM   #1
Engine Temp
I wanted to know at what temperature does the 98 Boxster run at? My runs just a little over the zero of the 180...is this correct?
986prospect is offline   Reply With Quote
Old 02-21-2007, 05:07 PM   #2
blkboxster
Guest
Posts: n/a
i think that may be high,not sure though
Old 02-21-2007, 05:13 PM   #3
Send a message via MSN to CJ_Boxster
Its ok if the needle hovers on top of the zero. Normally on a warm or normal temp day, the needle hovers over 0 in slow moving traffic and once you get moving it goes back between 8 and 0 and sometimes on top of 8
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 02-21-2007, 06:12 PM   #4
Thanks! I will see whats going on.
Old 02-22-2007, 04:08 PM   #5
180 "ish" is fine. The actual number is likely closer to 190. This question has been asked before and the consensus is the same. It will fluctuate with type of use (stop and go in 85 degrees with the AC on it will run hotter than 45 degrees at freeway speeds)
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 02-22-2007, 04:16 PM   #6
Hi,
+1 - your engine does not always (perhaps even rarely) operate at the exact same temperature. Load, Ambient Temperature, Barometric Pressure, Humidity, Fuel Octane, DME Maps, Avg. RPM, even Wind speed and direction can all, or in combination, affect what the gauge reads. So, don't obsess about a static number, but as racer_d suggests, look for a range...
Happy Motoring!... Jim'99
Old 03-03-2007, 04:00 AM   #7
Send a message via AIM to EuroProjektzKelvin
Temp
Your temp is based on your enviroment and driving condition.
Only worry if you've been driving for a long time and the needles in below 100 or its over 220
180-190 is very natural.
EuroProjektzKelvin is offline   Reply With Quote
Old 03-04-2007, 07:40 PM   #8
If you really wondering, there's a hack for the A/C display to show real-time sensor data. You can read the coolant temperature from there and know an exact number. I think 110 degrees C is probably about as high as you would expect it to go normally, low-mid 90s when at speed in cool air (that's been my experience at least). Anyone know the thread where it lists all the codes and how to access them?
-David
1995 Silverado V8 - Green/Tan (FOR SALE)
2000 Boxster S - Ocean Blue/Graphite Grey
2002 GSXR750 - Blue/White
http://www.darkoven.com/sig.jpg
David N. is offline   Reply With Quote
Old 03-04-2007, 09:22 PM   #9
-David
Hi,
It's not a hack, it's putting the Audi-sourced Climatronic into it's diagnostic mode. Only works through '00 MY. There are 35 different parameters which can be displayed such as cabin temp, coolant temp, oil temp, Fan RPM, Trus speed (in KPH), etc. Hope this helps...
Old 03-04-2007, 11:56 PM   #10
http://www.cb-racing.com/boxster_AC.html.. here u go this what ur looking for
clb0099 is offline   Reply With Quote
