Old 02-18-2007, 05:39 PM   #1
2.7L boxster questions
After giving my friend a ride in my boxster, he absolutley fell in love with the car. So we found a 2000 Boxster 2.7L with 68,000 miles. I have a few questions about the car...
1.)The car makes a clicking/ticking noise when you start the car, and we're wondering if that's normal, because I believe the 911 makes a simular noise when you start the car.
2.) Is the clutch on the 2.7L supposed to feel different then the 2.5L? Like is the range/play different?
http://skrat.gopclan.net/Koreancelebs/newsig.jpg
*THE PICTURE ABOVE IS NOT ME, IT'S A KOREAN ACTRESS NAMED HAN GA IN*
Cars:
E36/7 BMW Z3 2.8L Roadster
1999 Porsche Boxster
krn986 is offline   Reply With Quote
Old 02-18-2007, 07:19 PM   #2
I have a 2000 and it doesn't make any sound that I would call ticking during the startup. Sounds like a bad starter to me. I can't compare clutches on the 2.5 and 2.7 sorry.
arp35 is offline   Reply With Quote
Old 02-19-2007, 05:25 PM   #3
The ticking/clicking noise continues for about a minute or too after start up.
Cars:
Old 02-19-2007, 05:32 PM   #4
Sticky lifter. ABORT ABORT!
(maybe)
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
Old 02-19-2007, 05:56 PM   #5
sticky lifter
I made two pre purchase tests on my base 2000.
I have a lot of ticking for about two minutes and none of the mechanics said anything about it.
I plan to change to a lower viscosityoil and se if there is some kind of change.
Btw, is it hard to change the lifters or can it do some damage if you don't rev the engine when cold
spongebob is offline   Reply With Quote
Old 02-19-2007, 06:04 PM   #6
(maybe)
Not necessarily. Something to investigate to be sure, but it could just be dirty and in need of an Oil/Filter change. Fresh Oil will clean it and it'll sound OK. The lifter could also be bad, but not likely as the lifters on the M96 aren't usually a problem. I wouldn't automatically run away if everything else checks out, I'd ask the seller to pay for an Oil change (with the proviso that if that fixed the issue and I bought the car, I'd reimburse him for half) Hope this helps...
Happy Motoring!... Jim'99
Old 02-21-2007, 08:04 PM   #7
Octane booster(fuel injector cleaner) would help to i guess?
Cars:
Old 02-21-2007, 09:16 PM   #8
Nope. Octane booster is generally worthless as far as boosting octane, and this happens inside the combustion chamber. The ticking is likely outside the combustion chamber in the valve train. Any repair work to the cylinder head is big $, and there is some risk that you may have a bent valve or something from over-revving. If the engine is gunked up enough to cause a sticking lifter from using cheap oil or not changing it frequently enough, that might indicate poor maintenance. I have zero ticking in my Boxster. Your friend might want to get a read-out of the over-revs as well. Could be a very expensive/risky Boxster. If you can't solve the ticking problem, I would pass. There are plenty of nice Boxsters out there.
arenared is offline   Reply With Quote
Old 02-21-2007, 09:27 PM   #9
Typically our flat six engines make a slight rattle or maybe a ticking sound at idle but it is very slight. I couldn't tell you if what you are hearing is normal without more info or a sound clip. PPI time if the buyer is serious about the car.
