Old 01-28-2007, 12:35 PM   #1
Angry Soft top not going down?
I've been having touble latley with the soft top going down, it just wont go down for some reason, however I did have it go down once and it went back up... I tried to put it down this morning and no go.
-Brian
http://skrat.gopclan.net/Koreancelebs/newsig.jpg
*THE PICTURE ABOVE IS NOT ME, IT'S A KOREAN ACTRESS NAMED HAN GA IN*
Cars:
E36/7 BMW Z3 2.8L Roadster
1999 Porsche Boxster
krn986 is offline   Reply With Quote
Old 01-28-2007, 01:31 PM   #2
Is your parking brake fully engaged? That seems to be the most common cause. Try putting the P-brake up and down a few times. If you can get it to work that way then it's probably a sensor switch with the P-brake.
denverpete is offline   Reply With Quote
Old 01-28-2007, 05:12 PM   #3
Click the e-brake up. Does the dash light come on? If not, the fault is probably the e-brake microswitch.
If the e-brake light works, unhook the top latch above the rear view mirror. Do the windows automatically drop? If not, the fault may be the microswitch where the latch engages.
If the windows do drop, perhaps the top switch on the dash is bad, or the relay?
http://i19.photobucket.com/albums/b1...dingAvatar.jpg
Sold September 4th, 2007.
Rodger is offline   Reply With Quote
Old 01-29-2007, 10:56 AM   #4
Yeah, the window does go down when you press unlatch the top.
Now it works...
-Brian
Cars:
Old 01-29-2007, 04:28 PM   #5
Doesn't that happen cause of the cold? Or is that only vinyl tops...
Miss my Boxster
Bavarian Motorist is offline   Reply With Quote
Old 01-29-2007, 04:44 PM   #6
I had a issue with that once,it happened because I tried to splice one of the wires for the rear spoiler switch hack via the contact wire for the top up/down button. The wire came loose in a couple of days,I had to learn how to soder,easy fix. You haven't been messing with the wiring have you?
