Old 01-27-2007, 09:12 AM   #1
Becker CDR-210
Does anyone have a picture of the back of the CDR-210 with the cd changer cable plugged in? I removed the radio and when looking at the back a yellow connector was plugged into the top left (6pin) connection. The next connection is and 8pin and it is plugged into the bottom slot. Where does the cd changer cable plug in? thanks
98OceanBlue is offline   Reply With Quote
Old 01-27-2007, 09:32 AM   #2
Pic added
Hope this picture helps.
Old 01-27-2007, 03:33 PM   #3
Tool Pants is offline   Reply With Quote
Old 01-28-2007, 08:44 AM   #4
Cable
Tool Pants can this cable be purchased at Porsche and will it enable the ipod to work?
Old 01-28-2007, 06:29 PM   #5
You can buy the cd changer cable from Porsche, but it is cheaper from Becker. To use it for an ipod you would also need the changer.
You are better off getting a 220 radio that has aux-in, or sending your 210 to Becker and they will modify it for an aux-in.
