Old 07-30-2025, 06:06 AM   #1
ABS issue at race car
I have an endurance race car with ABS from a 2000 Boxter (the race car is a 924/944). The ABS is stand alone and not connected to the anything else then the sensors, battery and ground. At the latest race we got a few lock-ups so my plan is to connect the MIL-light for the ABS but I'm not sure how that is supposed to work. My hope was to get some support from the experts here
Is the MIL active high or active low? I have tested both with and without one wheel sensor (left rear) connected but I can't get the light to get active. When the wheel sensor was disconnected we got rear wheel lock -up but no light.
Does the MIL need something else to work? Is it even a valid test to disconnect a wheel speed sensor?
It's not the best feeling to not know if the ABS works at the end of a long straight...
If more information is needed to be able to help, just let mee know.
Thanks in advance!
I'm not sure this is the right place to ask this type of question, so please feel free to move it to a better place.
Timrek is offline   Reply With Quote
Old 07-30-2025, 01:25 PM   #2
The Radium King's Avatar
pm me and i can email you wiring diagrams from shop manual if that helps (but 22 MB ...). you should also confirm part # on your abs pump as they differ depending on options - psm, e-diff, etc.
Old 07-31-2025, 12:27 AM   #3
You got a PM.
BTW: what is psm?
Old 07-31-2025, 08:11 AM   #4
porsche stabilty management. here's a link to the PET with the various abs pumps available ...
https://www.********************************************.c om/porsche-parts/hardparts.php?dir=986-97-04&section=605-00
>>> replace the **** with auto atlanta (one word) and fix 'com'
Old 07-31-2025, 09:23 PM   #5
thanx,
I'll have a look at my pump (likely on Sunday) to get the correct p/n.
Old 08-10-2025, 07:04 AM   #6
This is little strange, the P/N list at the link below does nor include the pump I have. Can it be different numbers in US and EU? MIne is from EU.
The number marked at the pump is 98635575500 and it is a 5.3 model
Old 08-19-2025, 02:44 PM   #7
For model years 97 - 00 it lists the warning light at pin 21
Same for model years 01 - 02 but it mentions 'not used'. I guess it would still operate though.
Marc_986 is online now   Reply With Quote
