Old 07-02-2025, 09:51 AM   #1
The oil pressure drops above 3000 rpm
Hello, I have a problem with the oil pressure. After replacing all the hydraulic lifters for a tic-tic noise with some of them, the noise stills.
The problem is oil pressure is low when rev the engine over 2500 rpm (driving highway for ex.), so the hydraulic lifter is discharged. Do you know where is the possible causes of a low oil pressure?
I have red that the chain tensioners charge with oil pressure and if they aren't hermetic can loose oil for it and pressure decrease.
heiwaz is offline   Reply With Quote
Old 07-02-2025, 10:48 AM   #2
I'd be looking at the oil pressure relief valve on the oil pump, possibly the pump itself.
Old 07-02-2025, 02:01 PM   #3
is the 25 and 26 parts?
Old 07-02-2025, 02:13 PM   #4
Yup........
Old 07-03-2025, 08:23 AM   #5
1998 Boxster Silver/Red
Yup........
That's a quick easy update.
JFP... alternatively... could it be a bad/faulty sending unit?
1998 Porsche Boxster
Old 07-03-2025, 12:37 PM   #6
Possible, but they don't tend to die that way, they just stop working completely. He could always substitute a mechanical gauge to find out if it is real or not.
The pressure relief valve on the pump can fail and blow open a soon as the pressure begins to build, suddenly dumping all the pressure.
Old 07-04-2025, 10:07 AM   #7
Thank you.
Old 07-04-2025, 10:08 PM   #8
I would also check the oil pump for wear.
And maybe also the net / filter of the oil catchup of the oil sump. Maybe it's clogged by old sealing material or something else.
Also make shure you run the right engine oil. 0W-40 is recommended from the factory. If you run a modern 0W-20 or 0W-30 that could also cause too low oil pressure. I think - they also have 0W-8 these days.
Old 07-06-2025, 04:04 AM   #9
If after replace the relief valve continue the noise, next step wiil check the oil pressure in the head and after oil pump. The oil suction cup in the crankcase was checked and is ok.
In the case after replace relief valve and the oil pressure would be low, what could be the problem? chain tensioners loosing oil? oil pump gears with excesive wear?
I have to mention that this hydraulic lifter noise started after the engine was repaired of water-oil mixed through one of the brass plugs in the cylinder head that was corroded.
Old 07-06-2025, 06:20 AM   #10
I would two things: 1. Replace the pressure sender with a mechanical gauge and test the system again. If the problem persists, 2. I would next be looking at the oil pump itself for excessive wear or pitting on the gears.
Old 07-06-2025, 09:30 AM   #11
The pressure sender is located in one of the head? I think the screw is M14x1,5
