Old 10-08-2024, 11:10 AM   #1
upgrading the stock cooling fans
Greetings,
I'm currently working on the resurrection of a crashed 2.5 986 , mainly damaged on the front , radiators and condensers, and front left lower arm
i thought of looking for upgraded fans to use along with OEM radiators to help
draw in more air, higher cfm . thus to cool down at a faster rate. ( i live in a very hot climate area )
are there any fans used in the 986 community that give more cfm than the stock fans , while being easily fitted in the fan shroud. and can be rewired to the Porsche connectors
i found this fan from Mishimoto to be nearly the same diameter as the factory one only with 1 extra blade i guess , not sure about other dimensions.
https://www.fcpeuro.com/products/mishimoto-10-inch-electric-fan-12v-mmfan-10
Best regards,
Hamad
Hamad89 is offline   Reply With Quote
