Old 09-05-2024, 07:37 AM   #1
serialize's Avatar
G8620-103 (03 Boxster S 6-speed) manual transmission and LSD flush
Hello, I'm looking for some guidance please.
Apologies for creating a new manual transmission flush thread.
I'm read through hundreds and pages of material regarding this and its all very good information.
I'm just left a little confused when it comes to my Boxster specifically, because I believe I have the LSD limited slip differential because of the PSM in my car. I was specifically not looking to get the model with PSM but when I was recently shopping for my used Boxster this one was the best overall condition, mileage, and least owners, just ticked all the other boxes.
I have some service history for the car, but nothing indicates the transmission oil being flushed or the diff (if there even is one??). My transmission code is G8620-103 and based on other posts, this should be the one with LSD.
So my question is, will I be flushing and filling 2 separate units, one for the gearbox and one for the differential?
Also, my biggest concern after reading for days about this topic, what fluid and what capacity for each:
Gearbox oil type and capacity?
Differential oil type and capacity?
I know the 2 oils to use are Shell Spirax S5 75W-90 and Mobil 1 Mobilube PTX 75W-90
We can't get either here in Canada, and the Porsche dealers (all of them, I called them all) say to use Porsche Classic GL-5 oil, but reading through all the research material this car will require GL-4 only due to corrosion to the brass internals. Has anyone else with the 6-speed and LSD gone this route like what the dealer is recommending?
Sunset Porsche online retailer is one of the rare ones that will ship to Canada and I can only get the Mobil 1 Mobilube PTX 75W-90 from them, but sounds like that is one of the original formulations that went into these cars so I'm fine with that and will be ordering, I just don't know if should only order 3 liters for the manual transmission or if I should order more to have enough to fill the LSD as well?
I would really like to flush and fill the manual transmission on this car since I don't think it has ever been done, I also plan to change the front motor mount and flush the coolant while doing that.
Thank you so much for any feedback and guidance on this.
serialize is offline   Reply With Quote
