Old 06-14-2024, 02:28 PM   #1
elgyqc's Avatar
Look what I found in the oil pan... any ideas?
I am doing maintenance (cam tensioner chain pads, RMS etc.) on the spare engine that was in my 2000 Boxster 5-speed for the last couple of years.
I dropped the oil pan and found these pieces of plastic.
I can't figure out where they come from and I don't like not knowing. There are some very small pieces of the same material in the oil filter, along with chips from the tensioner pads and some bits of sealant. The engine was running fine. The plastic looks like it could be a piece of the oil pan baffle in terms of colour and thickness, but the baffle looks pristine. I don't see anything broken in the bottom of the engine and there is nothing in the area of the camshafts that could be a source. It is not the tensioner chain pads. I did not drop the oil pan before installing the engine 3 years ago so I have no idea if this dates from before or after I bought it.
Thanks in advance...
Grant
Old 06-14-2024, 03:48 PM   #2
Maybe a broken piece from the AOS or PVC?
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is offline   Reply With Quote
Old 06-15-2024, 02:26 PM   #3
Those look like chain pad fragments to me. If in the head everything looks fine, it's from a previous pad that was replaced.
Old 06-17-2024, 10:57 AM   #4
Colour wise, the center one definitely looks like tensioner pad material, the rest are hard to tell. Do they all have a dark reddish colour? If so, then it's probably tensioner pad. The only other thing that is black and plastic is the oil pickup tube and the two swirl pots.
redpepperracing is offline   Reply With Quote
Old 06-17-2024, 12:35 PM   #5
78F350's Avatar
Chain ramps for the timing chains. Here's one with some chips. I've seen them much worse on a few other engines I've disassembled.
Old 06-19-2024, 10:10 AM   #6
elgyqc's Avatar
I don't think anyone has figured it out so far. Here is another picture. It is less obvious in the photo but the piece of plastic is black, not the dark brown of the tensioner pads. Also it is too thin to have come from the pads. It also seems to be curved, as if it came from a piece of tubing.
At least no one has come up with a suggestion that it is a piece of a critical part, so I am going to class it as one of the universe's unanswerable questions, and not worry about it.
Grant
Old 06-20-2024, 08:05 AM   #7
The only black curved plastic that I can think of are the swirl pots. Have you taken them out and inspected them? Maybe there are internal pieces that have broken off.
Old 06-20-2024, 10:22 AM   #8
Did you look at the CPS sensor? That also has a a black plastic case.
Old 06-21-2024, 03:59 AM   #9
Forum Member
Creación de marcas no exterior, desenvolvemento e promoción de sitios independentes, planificación e operación de SEO e SEM, comercio electrónico transfronteirizo, transformación do comercio exterior de fábricas, marketing B2B, marketing de contidos no exterior, marketing dixital transfronteirizo e axencias de deseño creativo. Consulta comercial - WeChat/Vietnam Zalo +84789225888, Telegram: @hanhtrinh24h
hoppizza is offline   Reply With Quote
