Old 11-20-2023, 03:06 PM   #1
O2 sensor codes
Looking for some insight please. Stock 1998 boxster manual, car was impacted pretty good on driver's rear quarter. 30 miles into drive home from collision center after repair, solid CEL comes on. I continued drive home, another 100 miles. Checked with Durametric, got P0140 - O2 sensor behind cat. converter cyl (4-6). Erased code, drove it again, after 8 miles solid CEL and took it home. Codes were P0160, P1121 and P0140. Cleared codes. Swapped post cat sensors left to right, drove, 24 miles in got solid CEL. Coded P0140. Since code did not follow sensor I cleared code again. Today drove 28 miles, car up to operating temp, no CEL ---until I hopped out at home to open the garage door. Didn't turn car off, hooked up Durametric got code P0140. Also captured actual value graph of all 4 sensors.
My question is does this graph tell me anything? Any thoughts or suggestions on what route I should take? This is the first time I have had to use my Durametric so bear with me!
Thanks.
SilverFarmer is offline   Reply With Quote
