Old 08-19-2023, 08:59 AM   #1
What's the best Header for a 02' 2.7
Hello..I'am going to be doing a free flow system for my 02' Boxster 2.7. And Iam looking for a good set of headers to complete the package,I have 987 air box,74 mm T.B, and the Plenum,plus 200 cell mid pipes,I will need the 02 sensor bung's,( maybe use those mini cat's ),.I do have emissions testing ( Tucson,az ) But I will be using the stud's so it will be easy to switch the header's out for the stock system,.. Thank's ! Frank
flmont is offline   Reply With Quote
Old 08-27-2023, 05:14 AM   #2
I got mine on Amazon. Chinese knockoffs but high quality welds. The only issue was sensor bung placement, but I have an row tune which negated the issue.
Sent from my SM-N976V using Tapatalk
Old 09-01-2023, 08:47 AM   #3
Thank's Ike84, I will check them out..! Frank
Old 09-18-2023, 11:01 AM   #4
To go all the way, consider the 987 MAF. (needs an updated MAF-table)
Magnaflow's got some reamly good 200 cel cats if you are building your own pipes.
Robert986 is offline   Reply With Quote
