Old 02-01-2023, 07:55 AM   #1
Porschephile
Tomikaze's Avatar
PSS9 w/ Rennline camber plates installation HELP
Guys. I’m halfway decent tinkering on my car so I decided to take this on. Never tackled any suspension mods so this is a first. Paperwork says should be done by a qualified installer and I’m starting to think it might not be me. Got all these parts used. Except the swift springs. Had to buy those new. Bilsteins a did not come with them. I’ve already stripped out the Allen key hole at the top of the damper shaft. I think I might be missing a spring hat for the fronts. Can anyone with this setup tell me if a spring hat is needed for the fronts? Doesn’t look like they came with the set even when new. Same with the rear? And then I have questions about assembling. Not sure how far down the shaft I need to tighten/position the step nut and camber plate. Researched online and searched the forum but did not find my answers. Buy you a case of beer if you help me install!?!!. Lol.
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
