Old 11-08-2022, 08:11 PM   #1
ECS Coil overs
Hi All. I purchased and had installed the ECS Coil overs. They dropped the car quite a bit , so not to bottom out, the installer set the softness to max and spring pre-load to the tightest available (all the way to the top). As a result, the car now bounces over smallest of bumps. Has anyone installed the same coil overs and if so, what settings did you use? Please help.
2000 Boxster S (986)
De-snorkeled withK&N Cold Air intake
Short Shifter 14mm spacers F&B
Secondary Cat delete
Top Speed Test pipes and Exhaust
NJBoxster2000 is offline   Reply With Quote
Old 11-10-2022, 06:00 PM   #2
986tate's Avatar
Reducing the preload should improve the ride and raise it up. You only need enough preload to keep the springs from flopping around
986tate is offline   Reply With Quote
Old 11-10-2022, 08:49 PM   #3
Didn't know ECS had their own line of coilovers. Interested to find out how well they work out for you.
Javi Cooper is offline   Reply With Quote
Old 03-26-2023, 11:53 AM   #4
ecs struts
Just wondering how much the coil overs were, my car needs struts and I wanted to see what some of the best after market ones were and how much they cost.
MaddogsMotorSports is offline   Reply With Quote
