Old 07-19-2022, 07:31 AM   #1
On the slippery slope
JayG's Avatar
P1371 & p1364
I have been having an intermittent misfire in cyl 5, occasionally throwing a CEL, but would see it on a code reader P305.
A couple of bottles of fuel system cleaner seemed to fix the P305 for a bit and it only happened at idle
I scanned with my durametric and now see P1371 Valve lift control check sum and P1364 valve lift control Cyl 5
any ideas on fixing?
If I drive it am I in danger of an engine failure?
2004 996 Targa Tip
Instructor - San Diego region
Old 07-19-2022, 08:29 AM   #2
Most likely a restricted oil passage in the valve control system, or a Vario Cam+ actuator unit.
