Old 06-23-2022, 12:36 PM   #1
Keith Newby's Avatar
clutch issue
I'm having an issue where the clutch pedal is found on the floor. It was fine the last time i drove it but a month later it's on the floor. I can pull it back up and the clutch works normally...with no issues. It's happened twice and I'm sure it's sinking back to the floor as I type this. I would think the return spring would keep the pedal where it belongs, but I haven't had a chance to look at it. It's a 2000 S with about 35k on the clock. Just strange. Thanks.
Keith Newby is offline   Reply With Quote
Old 06-23-2022, 01:04 PM   #2
More likely you are losing either the master or slave cylinder.
Old 06-24-2022, 07:32 AM   #3
worst case
Thanks Jeff...
Old 06-24-2022, 01:38 PM   #4
If the slave cylinder is leaking you will have fluid running down the left/drivers side of the transaxle.... most likely it's the master cylinder *plus* the return spring that are both bad.
casioqv is offline   Reply With Quote
Old 06-24-2022, 01:59 PM   #5
Bad slave or master cylinders do not necessarily leak externally, either can have internal leaks that allow the pedal to move.
