Old 04-24-2022, 01:25 PM   #1
Cool 2001Tiptronic turns over, runs and then dies
Any ideas/help welcomed.
I work away and during lockdown my car stood undriven at home started ocassionally but not driven.. when I got home recently and tried to start it all was not good.
Battery is fully charged.
Turns over, fires and runs for a few seconds and then dies.
RPM movement.
Sometimes if accelerator pressed it runs for a few seconds longer and then dies😩😩
The CPS is new so ( hopefully) should not be the problem ?
Any ideas ?
Skullb is offline   Reply With Quote
Old 04-25-2022, 04:02 PM   #2
That screams fuel issue. Filter? Bad gas?
stateofidleness is offline   Reply With Quote
Old 05-04-2022, 05:15 PM   #3
Beelzy's Avatar
Check to see if you can hear the fuel pump prime up when you turn the key, before you start it
It will be a one second buzzing sound coming from the right side by glove box.
Beelzy is offline   Reply With Quote
Old 05-05-2022, 09:32 AM   #4
Will do .
Old 05-05-2022, 01:43 PM   #5
1998 Boxster Silver/Red
I'd been wondering for years what was that noise.
I love this place.
1998 Porsche Boxster
Old 05-06-2022, 07:41 PM   #6
I'm betting fuel issue too but I did have a 996 with a bad dme that had those exact symptoms.
Woody
Old 05-27-2022, 09:13 AM   #7
UPDATE
Thanks to everyone on here for their invaluable help in fault finding and enabling me to finally get my porker running again.
I replaced the crank position sensor - car still had same symptoms - turns over but doesn’t fire , and when it does it dies immediately .
I put some more ( fresh ) fuel in just in case it was actually empty.- same old same old.
Got a can of MAF sensor cleaner😎 but thought I’d try the “test” I had seen on posts on this and other forums about MAF sensors i.e remove it and the car should start and run ( possibly enabling you to limp home or to a garage) - if it does start and run then possibly your MAF sensor is the problem.
Removed the MAF sensor to clean it but tried to start with the sensor removed and 😁😁😁😁😁😁yeeeeeeees. She started and runs.
Cleaned the MAF and let it dry.
Re-installed and ………no change - back to turn over fires and dies.😩😩😩
Thought to myself “ oh well at least I know to replace the MAF Sensor .- removed it again - retried without MAF sensor. yep still starts and runs - no fluke there. Decided to put the MAF sensor back the car until new one arrives - always the optimist- gave it a few more sprays with the cleaner - allowed to dry - inserted key - turned over , fired and ran like it used to .😁😁😁😁😁problem solved 👍👍👍
Of course it may be that the crank position sensor was not faulty all along But as I am not eager to repeat the polava of refitting the old one to find out , apart from a possible bench test I will assume I have a spare now.😎😎😎
Thanks to everyone for their help .
Gosh bless the internet and this forum .
