Old 11-03-2021, 06:46 PM   #1
Vza
08 Boxster Compression Test
Hi All, Going to do a compression test on my newly acquired 08 Box. Just want to be sure of the procedure:
Eng to operating temp
Pull all coil packs and plugs
Pull Fuel pump fuse
Disable Ignitions Sys(not sure how)
Attach Comp.gauge
Throttle to the floor Crank 5 or so times
Repeat for other cylinders then repeat with squirt of oil in each
Just not sure how or why to disable ignition sys when all the coils are removed anyway. Can I just un plug the DME in the trunk to do this? Did it before can't remember.
Thanks V
Vza is offline   Reply With Quote
Old 11-04-2021, 08:25 AM   #2
Pull Fuel pump fuse
Attach Comp.gauge
Thanks V
When you crank the engine over for the test, crank it for a timed period for each cyl.
Say 5 seconds each cyl. trying to count crank revolutions is very difficult.
Also have a charger on the battery so you have as equal cranking power for each cyl. as possible.
Equal cranking power and equal cranking time for each cyl. is important in how it relates to balance of power from one cyl. to the next.
I don't have info on electrical layout of an 2008 so can't help with disabling ignition system.
The rest of your planned procedure looks good.
Old 11-05-2021, 02:17 PM   #3
Vza
Thanks...Anyone want to chime in on disabling the ignition sys. Or just unplugging the DME will do it? Thanks V
Old 11-11-2021, 10:22 AM   #4
Why do you need or want to? If you are just checking compression all you need to do is remove the plug & fuel pump fuse, crank it over for a set amount of time, then move on to the next cyl. Dont need to make it more complicated.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 11-12-2021, 06:54 PM   #5
Vza
Thats what I thought. Just wanted to be sure.
