Old 10-22-2021, 09:18 AM   #1
996 gauge upgrade, Automatic gauge Manual car
I recently completed the 996 gauge upgrade in my 2001 S 6speed 986. Once I got the 996 gauge I found out it was from a 2005 automatic car and I was not able to return it. I was able to change the face on the water temp/fuel gauge. And every thing is working fine accept when I first start the car I will get the Tiptronic emergency run message, And when I pull accept on the OBC it will go away and I will not see it again until the next time I start the car. I tried to disable it with durametric with no luck.
Any suggestions?
Race is offline   Reply With Quote
Old 11-11-2021, 07:59 PM   #2
Okay lets go at this from another angle.
Is it possible to reprogram the LED display in the instrument cluster?
Thank you
Old 11-12-2021, 05:44 AM   #3
The panel is looking for the Tip's computer and cannot find it. I am not sure this can be disabled or programmed out.
