Fuel pressure test or vacuum leak test?
Hi all. So I have I missfiring 986 under acceleration and it does try to cut out when I come to a standstill.
I’ve replaced the MIF, the air filter, engine oil and filter change, plugs and I’ve cleaned the inlet manifold, I’ve had a look for basic leaks and found nothing, my Durametric tool shows no engine faults. Is the next best thing to do - to check the fuel pressure with a fuel pressure gauge or to do a vacuum leak test with a smoke thingy? Sorry I don’t know it’s name 😁 |
Looks to me like you have 3-4 different threads going on the same issue. Makes it very very difficult to follow your issue and or help. |
| All times are GMT -8. The time now is 01:11 AM. |
