Old 06-07-2021, 02:06 PM   #1
AOS issue again !
This is my 3rd AOS in 2yrs it reads 3.20-3.75 back and forth at idle ,..is it time for the high dollar version or is this a maintenance item ?? Thanks Frank
flmont is online now   Reply With Quote
Old 06-07-2021, 03:31 PM   #2
3.2 - 3.75 what? Inches of water vacuum? Loafs of bread?
Old 06-07-2021, 09:32 PM   #3
Originally Posted by flmont View Post
This is my 3rd AOS in 2yrs,.. is it time for the high dollar version or is this a maintenance item ?? Thanks Frank
Hi Frank, did you used OEM parts on the previous two AOS replacements? Just curious about the low one year lifespan of those AOS..
Old 06-08-2021, 08:29 AM   #4
Sorry JFP yes In.of H2O and yes Gilles I used Porsche OEM parts,
Old 06-08-2021, 08:49 AM   #5
The values you posted are low vacuum, as the AOS does not produce vacuum, but regulates its level in the sump, and the only failure point is when it goes over 6 inches of water, it may not be the AOS. Weak vacuum could just be a vacuum leak in the intake system, or the engine was not fully warmed up before testing.
Old 06-08-2021, 05:00 PM   #6
Thank You,..Sir..I will look into that..Frank
