Old 05-02-2021, 05:42 AM   #1
truegearhead's Avatar
Alternator Wiring Question
For I hope this isn't a duplicate post, I just posted it but it seems to have disappeared..maybe a hit preview. Anyways, I'm trying to finish up the wiring on my swap and having trouble with the alternator. I have the main power connected but I can't find a wiring diagram for the blue wire and the small red wire. I believe the blue wire is for the voltage gauge but no idea on the small red wire. Does anyone know where this goes?
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 05-02-2021, 12:31 PM   #2
Is that coming off the hot side? I've never looked at our alternator but I've not seen a setup like that before. Thats too small of a guage to be the primary feed to the starter i would think. Maybe someone added that to an accessory? Or it may feeds directly back to the dme to monitor output. Sorry, I'm sure that's not much help but I'm interested in finding out.
Sent from my POCOPHONE F1 using Tapatalk
Old 05-02-2021, 01:27 PM   #3
911monty's Avatar
Per the Bently Electrical wiring diagrams EWD-54 that red wire feeds a 40amp Maxi fuse at Relay support 2. The Maxi fuse powers the relay and SAI pump so you will just remove. The blue wire on EWD-15 is to the charge indicator (Voltage gauge) as you previously stated.
Old 05-02-2021, 01:40 PM   #4
Interested in this as well as where the big wire on the alt goes to (ultimately the battery obviously, but does it to to the junction at the top of the engine, toward the firewall? Cable 19?
So is the small red wire going to the 40amp maxi fuse or relay support 2? 2 very different things.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 05-02-2021, 02:58 PM   #5
911monty's Avatar
The small red wire goes to the 40amp maxi fuse. The "Case at relay support 2" is a description for location. The large wire goes to terminal 30 at the firewall, then to the current distribution panel, then to battery.
Old 05-02-2021, 04:37 PM   #6
So it's a direct feed to the sai pump it looks like? I guess that makes sense as you would want this powering up immediately if called for.
Where did that diagram come from? I am a bit confused why it makes mention of an egr circuit.
Old 05-02-2021, 04:41 PM   #7
came from the FSM
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 05-03-2021, 02:28 PM   #8
awesome thanks guys, so it sounds like I only need to connect the large cable which goes to the battery and I'm all set.
2003 911 C2
Old 05-03-2021, 02:30 PM   #9
Well, you need the small red wire connected also.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 05-03-2021, 02:45 PM   #10
911monty's Avatar
Yep!
No his Audi powerplant is far from stock and has no need for SAI. Maybe an airplane nav light
