Old 04-07-2021, 06:15 AM   #1
freserf's Avatar
Recommended Oil Filter
I just purchased the LN Engineering spin-on filter adapter and wanted some feedback from you guys. I have read a few comments on what others have used and what they recommend, but would like more input. I am leaning towards the K&N HP-1007 spin-on filter ... have never had any trouble with K&N filters across multiple vehicles. Have any of you used the K&N filter? Thanks for any input.
freserf is offline   Reply With Quote
Old 04-07-2021, 06:45 AM   #2
I use the NAPA Gold filter that is recommended by LN, why would you not?
2ata is offline   Reply With Quote
Old 04-07-2021, 07:02 AM   #3
100%, no need to overthink it.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 04-07-2021, 07:43 AM   #4
The K&N is overpriced and not as good as the NAPA filter.
Old 04-07-2021, 08:09 AM   #5
Speaking of the LN spin on adapter - are there any similar adapters (for stock or aftermarket filters) that have oil line takeoffs built in to them? I know the DOF kits come with such a thing, but I haven't seen any sold individually. (Sorry, not trying to hijack the thread).
Sent from my POCOPHONE F1 using Tapatalk
Old 04-07-2021, 08:49 AM   #6
First of all, the DOF system takes oil from the cylinder head, not the filter. The IMS Solution, which is a patented design, uses the spin on filter adaptor. There are filter adaptors with AN lines on them to remote mount the filter itself, but I do not know of anyone other than LN that makes a quality spin on filter mount for these cars, possibly because the market size is so small.
Old 04-07-2021, 09:01 AM   #7
freserf's Avatar
Suggestions from others on other forums. But if you guys have used them without issue, I would trust that information ...
Old 04-07-2021, 11:52 AM   #8
Wix # 51348 .......... done ! I have been using these since Jake built my engine . It's a quality filter and available locally and online .
rfuerst911sc is online now   Reply With Quote
Old 04-07-2021, 12:06 PM   #9
Try the 51348 XP (IMS Solution cars) or the 51042 XP for non Solution cars. The XP filters are designed for use with full synthetic oils, and offer a slightly finer micron porosity in the filter media.
Old 04-08-2021, 02:41 AM   #10
I am using a semi-synthetic oil in my car based on oil analysis ( many samples ) and Jake reviewing those samples . I will stay with the Wix # 51348 . But my engine is far from stock so your results may vary
Old 04-08-2021, 05:25 AM   #11
husker boxster's Avatar
FYI... Napa Gold filters are rebranded Wix filters.
1989 928 S4 5 spd - black
Old 04-12-2021, 04:38 AM   #12
freserf's Avatar
Thanks for the responses and input. It is always good to hear other points of view ... I am going to send off an oil sample at my next oil change to get a baseline with the factory filter setup. Then I will install my spin-on adapter and K&N HP-1007. Next I will use the NAPA Gold with oil samples for comparison. I'll try at least 3-4 different filters just for my own curiosity. I don't expect any amazing results.
