Old 09-30-2020, 01:20 PM   #1
Coolant vacuum
Just finished installing an engine and trying to fill with coolant. When put under vacuum, it pulls in ok, but only gets to 10 pounds, then it seems something clicks and drops back down. There are no leaks.
Is this a problem with the relief valve?
Thanks.
Newsguy is offline   Reply With Quote
Old 09-30-2020, 01:51 PM   #2
AutoMatic or Stick?
"YouTube Certified in Various Specialties"
Old 09-30-2020, 06:20 PM   #3
Manual. And fresh AOS too (from Porsche.)
-H. L. Mencken
Old 09-30-2020, 07:31 PM   #4
I had a similar problem recently after changing the coolant tank. Turns out, the Bleed valve was defective.
Do a pressure test. If it doesn't hold pressure, clamp off the overflow tube and fill the black top of the coolant tank with soapy water. Mine bubbled around the bleedvalve and when I took the valve out, was cracked inside. Replaced and held pressure. AIrlift vacuum held at 15 mm Hg.
lmnsblu355 is offline   Reply With Quote
