Old 09-15-2020, 02:33 AM   #1
Failed MOT, high CO
Hello boys! (and girls?)
I could use some pointers.. Today I failed the MOT om high CO :ah: box 2003 986s the story goes as follows:
2019 oktober: Car basically oem, everything running fine. Standard headers, cats (only rear cats here in Sweden) standard catback.
MOT-values
HC: 5 (200)
CO: 0 (at idle, limit 0,3)
CO at 2500 rpm: 0,0 (0,2)
Lambda: 1,01 (0,97 - 1,03)
Winter/spring 2020: switched to long tail headers (ebay), 200-cel cats (ebay), Brombacher sound version catback. After this I got a cel and the following codes:
p0441 (tank vent system)
p0159 O2 sensor ageing behind cat bank-2
p0158 O2 sensor behind cat bank-2
p0430 Cat conv efficiency bank-2
There was also a code related to o2-sensor ahead of cat bank-1 (don´t remeber which)
Initially there was some minor leaks that I fixed, I replaced the o2-sensors ahead of cat bank-1 and after cat bank-2.
After this I drove the car för some weeks, I noticed that p0430 kept coming back, I also notice a quite noticeable sooting om the right exhaust pipe (bank-1).
Yesterday I cleared code p0430 again, this time I also hade the P0139 (aging o2 sensor after cat bank-1 for the first time)
This morning I started the car, noticed that it smoked maybe a little more than normal but it was rather cold outside. All codes cleared, went to the MOT:
MOT-values
HC: 90 (200)
CO: 0,1 (at idle, limit 0,3)
CO at 2500 rpm: 0,7 (0,2) (This was measured on bank-1, bank-2 gave CO 0,5)
So I failed..
All in all, something is not right. I could suspect the new cheep ebay 200-cel cats, but why so much soot on just bank-1 exhaus pipe.. And what I understand the ebay-200-cel cats normally do work.
The plan was to put on my new intake-stuff IPD 74TB, 987 airbox and all, then I have a appointment at the tuner in oktober. But this cannot happen if the car doesn´t go as it should before the tune.
It feels ok to drive, no hesitation etc.
My plan:
-Replace the o2-sensors that arent replaced (bank-1 after cat + bank-2 before cat)
-Check sparkplugs, can a sparkplug have come loose and cause a air leak on one bank?
-Open up the intake, plenum etc and see if there is oil residues there. If oily, switch AOS.
-Clean MAF (Or should I just buy a new one? it´s a bit hard to test since the car feels like it runs fine)
I would appreciate all kind of ideas on how to track this problem down, I have Durametric so is it anything I should test?
A long-shot: I take it that if the ECU doesn´t see that the car goes up to operating temp, then it remains in open loop. Can this be verified with Durametric? On the temp-meter in the cluster it looks like it is up in temp.
Sorry for the looong description :-)
Last edited by Robert986; 09-15-2020 at 02:44 AM. Reason: Regrouping the MOT-values so it will be easier to read
Old 09-15-2020, 10:07 AM   #2
Hi Robert,
I have similar set-up, but on 2.7 engine (with manual).
As I installed the long tail headers and downpipes with 200 CPI cats - the car run pretty nice compared to old OEM exhaust.
On getting ready for MOT, I swapped new Bosh spark plugs (with 4 leads each but non platinum). Car run a tiny bit rough as of what I could feel.
Went to the MOT and failed due to too high CO%.
Also the CAT efficiency CEL showed up couple of times a week. So I swapped also all Lambdas. Car still did run a bit rough.
Next I installed new and NGK Platinum spark plugs (NGK BKR6EQUP). Now the car run very nice.
Cleared the CEL's with Durametric and went to MOT.
The inspector looked at the exhaust after I told him what I had done to improve the CO%.
Initial test was again too high CO%, but then he heated the CAT's real well for 5 minutes on approximately 2500rpm and then the car had CO% on 0,08!!!
Reasoning he told was that the 200 CPI 'race cats' are metal based and required more heat to operate than ceramic CATs (he said that he has same style 200 CPI metal CATs on his Impreza...).
For next MOT he told to drive the car for 10 minutes with very high rpm (actually told to drive against the rev limiter ) immediately before the MOT to get the CATs very hot. Then the CO% should clear easily.
Anyhow, I'm planning to take my car to same inspector also on the following years to come
2001 996 C2 Manual
Old 09-15-2020, 01:33 PM   #3
Originally Posted by pilot4fn View Post
Hi Robert,
Thanks a lot, great input!
I did heat the cat:s quite a lot before MOT, when it failed I got a chance to heat them more and went for a 20 min very VERY spirited drive.. Still the same values at 2500rpm, 0,7 on bank-1 0,5 on bank-2.
So I have a feeling there is another bug somewhere..
I now also checked the old exhaust pipes to see if the right side (bank-1) had a lot of soot.. None.. Both pipes where super clean. This tells me that it shouldn´t be a major problem with the engine, like major leaks in the cylinders.
Idea-1 -Can it be that the gaskets provided with the ebay-headers are of low quality so there is a small air-leak before the pre-cat O2 sensor, thus giving a slight rich condition? (however lambda after cats tells different) Would a slightly rich condition pre cat be mitigated by the cat to give a good lambda in the tailpipe?
Idea-2 -Could it be a leak in the AOS, so I get a lot of oil residue in the intake? Will check that tomorrow. Spent today with cleaning up in the garage to give room for further examinations.
Old 09-15-2020, 09:35 PM   #4
I'd believe that both ideas you mention are feasible.
Easier to check first is the AOS failure. As the engine is warm and idles, open up the oil cap in the trunk. If it has a very high vacuum (I guess hard to lift the cap), then you'll have most likely a failed AOS.
Also, the inteke plenums would have oil inside if AOS has failed.
2001 996 C2 Manual
Old 09-18-2020, 01:00 AM   #5
Checking AOS
Ok, first we look at the AOS..
I did the oil-cap-test.
It really felt easy to open the oil cap, no powerful vacuum at all, but I realize this is totally subjective since I have no vacuum meter.
I then went on and popped the plenum & throttle body. I must say, there is some oil in there, but is it normal levels? As you see my finger get quite soaked when I scrape the inside of the plenum, I don´t see a lot of oil in the actual manifold. at least not a lake.. ;-)
So, does this mean that my AOS is not up to the job? Should I change it? I have been tracking with R-compounds, but not since last year, so I cannot imagine the oil beeing that old.
As you can see the throttle body was kind of dirty as well, cleaned this up.
Old 09-18-2020, 08:50 AM   #6
I had similar amount of oil in my plenum as I opened it on the spring this year while cleanign the throttle body which also looked like yours. Clened also the plenum and drove for a couple of weeks and then one morning the AOS died with a large puff of white cloud
This could mean that also your AOS is on a way out - somebody more knowledgable could chime in on that.
2001 996 C2 Manual
Old 09-18-2020, 10:47 AM   #7
Thanks for input, I guess it cannot hurt to change the AOS, just more work..
Old 10-15-2020, 03:58 PM   #8
Update:
Switched AOS, MAF, o2-sensors & spark plugs, still no luck.. Then I put back the oem cats, instead of the cheap eBay ones. o2 and HC back on zero again!
Anyone else had bad luck with eBay cats?
Old 10-15-2020, 09:36 PM   #9
Update:
I had similar issues with 200 CPI cats. On this thread at the answer #2 is the reasons for the issues and how the MOT was cleared.
2001 996 C2 Manual
Old 10-16-2020, 02:06 PM   #10
Hmmmm... So heat.. extreme heat? What about if I put exhaust wrap all the way over the cats? I have wrapped the headers, maybe try to wrap the cats to. Anyone tried that?
Old 10-17-2020, 10:41 AM   #11
edc
550 Anniversary
edc's Avatar
Passed my MOT yesterday with eBay manifolds and 200cell cats. It was close the year before. For 2 or 3 years before that it passed with 100 cell cats.
