Old 08-15-2020, 05:52 AM   #1
Aluminum plate under trany
I was working on my P-car the other day and had to take off that aluminum plate covering the trany which is held in place also by those 2 long aluminum suspension bars.
What I was wanting to know is if that plate has anything to do with holding the suspension together or as far as I can tell besides being a skid plate for the trany pan its entire function in life is to bring air up from under the car by way of those 2 rubber flaps to help cool off the trany.
Is this correct ?
99 Roadster base / 5 SP Tiptronic
18" Turbo Twist wheels / Arctic silver W/Black leather Int
Rear wing W/Brake light / 47,000 miles
Side skirts / Bought from original owner
99Roadster is offline   Reply With Quote
Old 08-15-2020, 06:32 AM   #2
No considered part of the suspension
Old 08-15-2020, 06:50 AM   #3
Who's askin'?
maytag's Avatar
It's DEFINITELY considered part of the suspension / structure. You do NOT want to even lower the car into its wheels without that plate on, or you'll find lots of stuff moves, and it's harder to get it on again.
Old 08-16-2020, 09:57 PM   #4
+ 1 if you remove the wheels before removing the aluminum triangle helps to remind you Not to lower the car without the support bracket.
Old 08-17-2020, 05:57 PM   #5
Qingdao's Avatar
uh oh... I don't remember tossing this, but I can't find it in the garage now.
BUT looking back on the pictures where I had the 4.3 in the car still I think I couldn't use it anyways. My trans bracing I made goes under the trany and would be in the way of this plate thingy. Its probably for the best though. I was concerned about my trans brace being less than secure. I guess I can fab up some bracing to secure it to each side subframes.
^^^ kinda like this.
'98 PP13B powered "RX986"
Old 08-15-2020, 07:34 AM   #6
There Is No Substitute.
rick3000's Avatar
The plate acts as a brace between the rear suspension, as maytag said, you do not want to put any weight on the rear suspension without the plate installed. If you are tracking your car and need to change the transmission oil frequently, some people drill a hole in the plate below the drain plug so the entire plate doesn't need to be removed.
Old 08-15-2020, 01:30 PM   #7
Thanks everybody for your reply's.....Yeah I wondered why they would only put a hole for the fill but not for the drain.
Old 08-17-2020, 05:46 PM   #8
Artist, 986S tinkerer
NewArt's Avatar
You may find that if you remove the plate when working on suspension parts or whatever, that you may need a ratchet strap to line up the plate holes with the bolts when re-installing.
Old 08-17-2020, 06:18 PM   #9
Who's askin'?
maytag's Avatar
Yup. I usually count on it.
Old 08-23-2020, 09:48 AM   #10
Ciao's Avatar
Is it possible to remove the exhaust, & replace with a different one, without removing the aluminum cover?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
