Old 08-12-2020, 04:04 PM   #1
Engine moisture?? (ew)
Recently purchased an '03 6-spd S with 86k miles. Today we opened up the engine cover to take a look....
Im hoping to hear from you all if this is normal or not??? Seems to be some moisture or condensation around the engine block and another lower hose. Help!!!
Here are the photos:
Chuckleski212 is offline   Reply With Quote
Old 08-12-2020, 05:57 PM   #2
Looks like oil fog and road grit. Doesn't look as if the engine bay has ever been cleaned.
have it steam cleaned or degrease it with a good engine degreaser.
Take your time get it as clean as you can.
Every where you can. above and below.
Once it is clean you will be able to tell if and where you have oil leaks.
A dirty engine bay just complicates any issues you may have.
A clean engine bay makes things easier to work on and easier to see issues.
I spent two days cleaning mine when I bought it with 45000 miles.
Now when I remove the engine cover I know in seconds if there is an oil leak.
Old 08-13-2020, 09:31 AM   #3
jaykay's Avatar
If you are able check the AOS hose going to the Throttle body perhaps that is the source of the oil mist film.
I cant exactly explain the pattern on the intake runner but I do recall seeing oil film on these engines
986 00S
Old 08-13-2020, 09:40 AM   #4
jaykay's Avatar
Originally Posted by Chuckleski212 View Post
I do like the 03 shift cable being split. They have different casing colours as well. I am wondering if I can replace 00 cable with the updated ones. Didn't think that this an option....I think my cables get clamped one ontop of the other with the engine cover
986 00S
Old 08-18-2020, 10:20 AM   #5
BYprodriver's Avatar
Get the Numeric Racing shift cables.
Old 08-19-2020, 07:48 PM   #6
jaykay's Avatar
I had them on for a bit.....way back. They did not make the right length which was really painful and shifting suffered; the lead time to make a new cable was prohibitive.
That said I found the noise and vibration transmitted into the cabin via the cables really awful. I pulled them off very quickly.
986 00S
