Old 06-26-2020, 01:38 PM   #1
Super Moderator
15% OFF H3R Performance Extinguishers!
Early access for our massive 4th of July promos start now!
For a limited time, receive 15% OFF of the best performing 2.5lb hand-held car extinguisher by H3R Performance!
The HG250R model features the clean agent Halotron which effectively extinguishes automobile fires without harming sensitive electronics or vehicle surfaces.
The extinguisher includes a mounting bracket for easy installation. Enter promo code FIRE15 during Checkout.
Click Here for H3R!
10% OFF All Liqui Moly Products!
Formulated and manufactured exclusively in Germany, Liqui Moly continues to provide the very best to keep your engine purring like a kitten and performing like a cheetah.
Many of their oils are approved or meet specifications set by Porsche, BMW, Volkswagen, and Mercedes-Benz.
Use Liqui Moly in your car for a longer lasting and better performing engine!
Take 10% OFF Liqui Moly Products when you enter promo code TAKE10 at Checkout!
Click Here for Liqui Moly!
10% OFF Hengst Filters!
With over 60 years of history and innovation in filter technology, Hengst is one of leading manufacturers of Air, Oil, Fuel and Cabin filters.
Now you can take 10% OFF Hengst part numbers ending in -M45 when you use the promo code TAKE10 at Checkout!
Click Here for Hengst Filters!
10% OFF StopTech Big Brake Kits!
StopTech Big Brake Kits exceed stock performance in two key areas: First, larger rotors increase heat capacity, allowing a driver to brake harder stop-after-stop with reduced chance of fade.
Second, stiffer calipers and stainless steel lines reduce system compliance, providing consistent pedal feel and confidence-inspiring responsiveness.
Take 10% OFF StopTech Bike Brake Kits when you enter promo code STOP10 at Checkout!
Click Here for StopTech!
10% OFF P3Cars Integrated Vent Gauges!
The P3Cars integrated vent gauges display it all - temps, boost, vacuum, speed, voltage and more!
Easy plug 'n play assembly with your choice of integrated OE vent or not.
Enter promo code P310 for your 10% discount at Checkout.
Click Here for P3 Gauges!
5% OFF All Sonax Car Care Products!
SONAX is the market leader in car care products in Germany, and one of the leading manufacturers worldwide.
The brand is represented in 100 countries around the globe. Whether it's in Motorsports, in the tuning scene, or in the world of classic cars: When it comes to the perfect presentation of automobiles, SONAX will always be on hand.
Take 5% OFF SONAX Car Care Products when you enter promo code SONAX at Checkout!
Click Here for Sonax Car Care!
5% OFF Clutch Masters Performance Clutches!
Clutch Masters has been a premier manufacturer of high quality performance clutches since 2002.
They've taken these years of experience and a clean sheet of paper to re-engineer their line of performance clutches to solve the clamping force vs. pedal pressure equation.
The proof of this success is available as a complete line of clutch systems for high performance street and racing use,
Take 5% OFF their entire lineup when you use promo code CLUTCH at Checkout!
Click Here for Clutch Masters!
5% OFF M7 Speed Products for Your MINI!
Are you ready to upgrade the performance and looks of your MINI?
Take advantage of this limited time offer and tune your ride with quality performance products by M7 Speed! M7 products are designed, tested and manufactured in the USA ensuring a perfect fit and finish.
Shop Gen 1, Gen 2 and Gen 3 performance products for your MINI today!
Take 5% OFF when you enter promo code M75 at Checkout!
Click Here for M7 Speed!
5% OFF All UUC Motorwerks Products!
UUC has become the premiere USA engineering and manufacturing source for BMW performance.
Their goal is to develop the ideal solutions without compromise in design or quality, and educate our customers about their cars, the performance enhancement potential, and the particular reasons their designs stand above all others.
Take 5% OFF All UUC Products when you enter promo code UUC at Checkout!
Click Here for UUC Motorwerks!
Dmitry at Pelican Parts is offline   Reply With Quote
