Old 06-05-2020, 10:14 AM   #1
Axle Bolts
Has anyone had problems with axle bolts coming loose and axle coming out of transmission??
I replaced a bad engine and after driving around for roughly 100 miles the drivers side axle came off the transmission, got it home and checked the right side and found some of the bolts were also loose. I ended up replacing all the bolts and pretty much spot torqued them. I have yet been able to get a torque wrench in there to properly torque them.
Thanks for any info on this problem and a way to not have it happen again would be appreciated.
rackets351 is offline   Reply With Quote
Old 06-05-2020, 11:10 AM   #2
BYprodriver's Avatar
Be sure all threads are clean & grease free. put a small dab of Blue thread locker on the axle threads before installing bolts & torque then to spec.
Old 06-05-2020, 11:11 AM   #3
You need to pull each bolt, clean it (use something like spray brake cleaner), blow of the bolts with compressed air, then put a small amount of medium strength (blue) Loctite on them, then torque them to spec. The problems will not return.
Old 06-05-2020, 12:15 PM   #4
Will there be cake?
tonythetiger's Avatar
Fact & 29ft/lbs.
Old 06-06-2020, 12:30 PM   #5
Thats basically what I did, thanks
Old 06-06-2020, 12:54 PM   #6
Artist, 986S tinkerer
NewArt's Avatar
I've had these flanges on and off numerous times for reasons I won't get into here. Torquing is easy with a good long solid extension bar done from outside the fender.
Old 11-14-2024, 05:28 AM   #7
charlie horse is offline   Reply With Quote
Old 11-14-2024, 08:49 AM   #8
Thanks for the pics of torque specs, charlie horse!
gonz is offline   Reply With Quote
